Garemlin
Member
Just arrived in the mail today. I must say I am really impressed with how fast it shipped considering it was just released on July 14th.
Package contents:
It comes with two screen protectors. That is it and that is all you need. It came packaged in a large envelope and sandwiched between two pieces of cardboard. Nice touch
Installation:
Installation was a snap. Took a total of five minutes from package open to install complete. I installed mine in the bathroom with the shower running on hot to create a humid environment. This helps keep dust down. I cleaned my screen with a microfiber cloth and a few squirts of eyeglass cleaner. After that I cleaned it again. That is just the OCD in me. I laid the protector down on the screen to make sure it fit and to see what alignment would be before removing the protective film. Peeled part of the back film away and aligned it with the top and slowly applied it downward using a credit card to smooth it as I went. When application was done I used the credit card to smooth out the edges. Then I peeled the top protective layer off. Finished!!!
Results:
I must say that I am extremely impressed with these protectors. I have a regular Steinheil on my Droid and it was cut just very slightly big so it never laid flat on one corner. Not the case here. There is only a very slight gap at the top and bottom. When I say slight I mean hairline. There is zero bubbles or raising. Clarity is unaffected. Touch is just slightly less smooth than bare glass but nothing that affects performance. And nowhere near anything like you get from went apply films.
Conclusion:
I highly recommend. Get over to SGP Store and order one now.
SGPStore.com
Package contents:
Installation:
Results:
Conclusion:
SGPStore.com
