Root Step by Step Backup Guide for Huawei Fusion 2
shagerty
Have you been tinkering with your Fusion and lost some important information?
Well it is the time in the development of this device that I would like to introduce a Backup Guide!
BEFORE EVEN READING THIS MAKE SURE YOU HAVE AN EXTERNAL SD CARD FOR YOUR PHONE!!!
Step 1: Save all contacts to your google account.
Step 2: Save all of your music photos and videos to your External SD card.
Step 3: Root your Fusion 2 using my guide here.
Step 4: Download Titanium Backup Root AND Titanium Backup Pro Key From Google Play Store (and don't be a cheap ass and pirate the pro version just splurge the $5 and get it, you won't regret it the apps developer is incredible!)
Step 5: Open Titanium Backup (after enabling USB Debugging) and grant super user access to Titanium Backup.
Step 6: Press the Menu Key on your Fusion 2 (the haptic key with 4 horizontal lines on it)
Step 7: Select Preferences Found under General in the Main Menu.
Step 8: Scroll Down to "Backup Settings" and select "backup folder location" navigate to your external SD card. (if you don't have one get one, you need it for backups and saving data)
Step 9: Select Batch Actions.
Step 10: Look for "RUN Backup all user apps + system data" Hit RUN. This program will now backup all of your applications and their data.
Step 11: Install CWM Using my guide.
Step 12: Turn Off Phone
Step 13: Hold the Power and Volume Up Buttons Simultaneously Until your phone boots into CWM.
Step 14: Select Backup and Restore by using the Volume Keys to Navigate CWM, and the Power button to Select the option "Backup and Restore".
Step 15: Select Backup and let CWM do it's magic. Once it say's "Backup Complete" Select "Reboot System Now".
Step 16: Once the system reboots you should now be totally backed up!
Brought to you by Shagerty
Remember to Thanks, Like, Thumbs Up, or Donate if You find yourself in a generous mood!
what does the clockworkmod Backup and restore option do exactly? does it save the image of the rom or the filesystem? does it allow me to revert back to the original android version i had installed when i did the backup? basically is this all i need to do if i dont care about the contacts or the appz or any data on my phone other than the ability to restore the factory ROM in case one of the custom roms doesnt work or i dont like it or something....
