Stick it! (video player)
nstallion
Android Expert
Just discovered this application today: https://market.android.com/details?id=com.myboyfriendisageek.stickit
I've never seen an app able to do this before and I hope more developers figure out how. It basically makes a video player window that will stay on top of other applications. It's resizable, can be dragged around and supports lots of video codec types. A great example of usage would be browsing the web or doing work WHILE watching a video.
Seems great for a powerful tablet like the Prime.
P.S. I don't know the developer and have nothing to do with them. Just discovered this app on reddit earlier as the dev was announcing a calculator which works in the same way (and is free).
Now if only you could develop a Calculator App that overlaid my moey App EasyMoney I for one would pay you without question.
Well I never... You are absolutely correct.
Just installed and tried it with EasyMoney and it's perfect.
Many thanks to you and I must also thank the developer.
