That is correct. It does seem to mount the files from the stick, but then I cannot find them.As far as I know, your N7 has been rooted for StickMount.
Harry
Answer to points 1-3 is Yes.If you restart, plug in your OTG-usb cable with storage attached:
1. Do you see 'Stickmount searching', then a notification, then a message stating Stickmount... Active Mounts?
2. Do you have an ongoing notification Stickmount Mass storage device mounted?
3. Is Stickmount in your list of allowed apps in Superuser or Supersu?
4. What to you see in ES Explorer when you navigate to /sdcard/usbstorage/?
It sounds as if your OTG-usb cable is ok since you can use NMI, but you lose the write capability to your storage. Mine works perfectly with Stickmount for read/write/stream.
do you have es set to display hidden files and setup as root? check out your settingsbtw im gonna move this over to All things root
FWIW, I get different results depending on which (rooted) ROM is installed.
With (rooted) stock 4.2.1 (JOP40D), I use StickMount and everything seems to go fine, with the mount at /sdcard/media/usbStorage/sda1.
When I tried using StickMount on a recent CM10.1 nightly, the mount would happen, but the permissions were screwy and the results I got with root-privileged file explorers would vary depending on whether I navigated to the mount via /sdcard/... or /data/media.
Turned out that CM10.1 performs the mount itself - and StickMount was actually interfering with the correct operation of the auto mounting performed by CM10.1; once I uninstalled StickMount, everything was fine. It does put the mount at a different spot, though. I can't remember the location at the moment. You can find it easily enough by typing "mount" in a terminal emulator.
Hope that helps.
eu1
PS What ROM/kernel are you using?
