Stick with Honeycomb for a while?
gordonwd
I had one of the units with severe random reboot problems after the first ICS update. I RMAed it back to Asus and just received a brand new one from them (after 4 weeks!!). This one has a "C1" serial number, whereas my original started with "B", so probably a newer hardware revision.
The good news as far as I'm concerned is that this one came with Honeycomb (3.2) installed. I'm really concerned about going through what I did earlier, even though the latest .13 release is supposed to have fixed the reboot problem, but might have introduced some new problems.
So can I just not update the firmware for a while to see if there is yet another, more stable update? Or can an update somehow be forced to download and install?
Just to close this out, I discovered that you can only postpone the update up to 3 times, and for a max of a day at a time. So I went ahead and updated it, which was build .13, and so far everything is OK. On my first go-round with the ICS (Android 4.0) update, it started failing drastically pretty quickly.
And so far I have not noticed any severe battery drain issues. Of course, I probably use the tablet different from many: no games, only turn on wi-fi when I need it, manually sync apps, keep screen brightness down (auto-brightness seems too bright), etc.
