I'm still running the leaked 2.2 with FlyX, a little bummed that Pandora doesn't work. Can anybody suggest another ROM, and the best way to update? Thank you!
Best way would be to SBF back to the stock 2.1. Then let the phone take the real OTA 2.2. Once on stock 2.2 ota, then you can root and go from there. Also you can get the SBF for 2.2 now, so you can screw with it without fear of bricking. Thats the correct path to the real 2.2.
I did the exact method I described above and I did not have the OTA. It just seems quicker to flash the 2.2 OTA SBF; then root it with the 1 click root; install the bootstrap app; then install the ROM of your choice.
