Help Stock 2.2 - HOW?
IamAl
How do I reinstall a stock version of Froyo? I have messed around with a few files, etc and want to go back to my stock version.
Normally I'd say just do a factory reset, but it would depend on exactly what files you've messed around with....
The files I changed were the recovery file and the xbin folder - I did this while trying to get the lagfix working, but needed the 3e? version of the recovery file in order to do it. I had upgraded to Froyo via Kies, which worked fine.
If I did a factory reset, what state does it leave the phone in? Would it go back to Eclair or back to froyo as at the upgrade point?
