Help Stock alarm clock not going off
kingdave
I'm having major issues with the stock alarm clock on my DHD.
It is set to go off Monday to Friday at 6.15am but it only ever goes off on the Monday morning.
- My phone is always on
- Alarm volume is set to max
- I have no task killer installed
- All the days I want it to go off are checked in the alarm setting
What else could it be?!
I've had the same issue, Dave. I just got this off another forum:
'Clear the apps cache and reboot the phone
Settings > Applications > Manage applications > search for alarm or something like that, select and press the clear data button'
I just did it. I'll see tomorrow, if it wakes me up! (I'd try it right now, but, IME it always goes off if I set it for a time in a few minutes from when I set it, but I've woken up with my husband's alarm one minute prior to when my alarm is supposed to go off, and stared at my phone NOT going off! :mad:)
fingers crossed,
=) Cynthia
I had the same issue and it was an easy fix. You have to set the volume level when setting the alarm! ( I mean when you are in the alarm screen, just before you choose "done")
Sounds silly but nothing fixed this until I did just that.
