Root Stock build.prop download
Belinrahs
Below are the contents of the stock build.prop. I grabbed it untouched from my phone and am placing it here so it's easier to review and make changes for those who wish to do so.
DOWNLOAD STOCK BUILD.PROP HERE
NOTE: You may need to right-click on the above link and Save Link As.
Code:
ro.ril.oem.ecclist=911
ro.ril.set.mtusize=1472
ro.com.google.clientidbase=android-htc
ro.com.google.clientidbase.yt=android-virgin-us
ro.com.google.clientidbase.am=android-virgin-us
ro.com.google.clientidbase.gmm=android-htc
ro.com.google.clientidbase.ms=android-virgin-us
ro.bt.tetheringUI=0
ro.usb.tetheringUI=0
ro.product.brand=virgin_mobile
ro.product.model=HTCEVOV4G
ro.cdma.home.operator.alpha=Virgin Mobile
gsm.sim.operator.alpha=Virgin Mobile
gsm.operator.alpha=Virgin Mobile
ro.cdma.home.operator.numeric=311490
gsm.sim.operator.numeric=311490
gsm.operator.numeric=311490
gsm.sim.operator.iso-country=us
gsm.operator.iso-country=us
ro.da1.enable=true
persist.radio.voice.dom.roam=0
# begin build properties
# autogenerated by buildinfo.sh
ro.aa.customizationid=363616
ro.aa.project=Shooter_ICS_35_S
ro.aa.romver=1.13.652.2
ro.aa.maincid=SPCS_002
ro.aa.cidlist=SPCS_002
ro.aa.rid=87
ro.aa.modelid=PG8610000
ro.build.display.id=1.13.652.2 710RD
ro.aa.skulist=652
ro.aa.taskid=259760
ro.aa.mainsku=652
ro.cwkey=SPCS_002
ro.build.id=IML74K
ro.build.display.id=IML74K
ro.build.version.incremental=372137.2
ro.build.version.sdk=15
ro.build.version.codename=REL
ro.build.version.release=4.0.3
ro.build.date=四  5月  3 22:08:29 CST 2012
ro.build.date.utc=1336054109
ro.build.type=user
ro.build.user=
ro.build.host=ABM011
ro.build.tags=release-keys
ro.product.model=PG86100
ro.product.name=htc_shooter
ro.product.device=shooter
ro.product.board=shooter
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=HTC
ro.product.locale.language=hdpi
ro.wifi.channels=
ro.board.platform=msm8660
# ro.build.product is obsolete; use ro.product.device
ro.build.product=shooter
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=1.13.652.2 CL372137 release-keys
ro.build.changelist=372137
ro.build.fingerprint=virgin_mobile/htc_shooter/shooter:4.0.3/IML74K/372137.2:user/release-keys
ro.build.characteristics=default
ro.build.project=Shooter_ICS_35_S:259760
ro.product.version=1.13.652.2 710RD
ro.build.languageremove=0
ro.build.sense.version=3.5
keyguard.no_require_sim=1
# end build properties
# system.prop for shooter
ro.sf.lcd_density=240
sf.debug.enable3D = 1
debug.fb.rgb565 = 0
debug.sf.hw = 1
debug.composition.type = c2d
debug.enabletr = true
debug.qctwa.preservebuf = 1
rild.libpath=/system/lib/libhtc_ril.so
# Default network type.
# 4 => CDMA mode preferred.
ro.telephony.default_network=4
# system props for the data modules
ro.use_data_netmgrd=true
persist.data_netmgrd_nint=8
persist.data_netmgrd_mtu=1472
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
# The OpenGL ES API level that is natively supported by this device.
# This is a 16.16 fixed point number
ro.opengles.version = 131072
# This is a high density device with more memory, so larger vm heaps for it.
# Change to 32m, due to 2.3.3 GB already change to 32m
# For ICS project, default 32m/48m
dalvik.vm.heapsize=128m
dalvik.vm.heapgrowthlimit=48m
# For the default value of agps
ro.ril.def.agps.mode = 2
# For emmc phone storage
ro.phone_storage = 0
# For ext4 file system
ro.ext4fs = 1
# For FOTA setting (leave empty value to use default)
ro.htc.checkin.url = http://andchin.htc.com/android/checkin
ro.htc.checkin.crashurl = http://andchin.htc.com/android/crash
ro.htc.checkin.url_CN = http://andchin.htccomm.com.cn/android/checkin
ro.htc.checkin.crashurl_CN = http://andchin.htccomm.com.cn/android/crash
ro.htc.checkin.exmsg.url = http://fotamsg.htc.com/android/extra/
ro.htc.checkin.exmsg.url_CN = http://fotamsg.htccomm.com.cn/android/extra/
ro.htc.appupdate.url = http://apu-chin.htc.com/check-in/rws/and-app/update
ro.htc.appupdate.url_CN = http://apu-chin.htccomm.com.cn/check-in/rws/and-app/update
ro.htc.appupdate.exmsg.url = http://apu-msg.htc.com/extra-msg/rws/and-app/msg
ro.htc.appupdate.exmsg.url_CN = http://apu-msg.htccomm.com.cn/extra-msg/rws/and-app/msg
# release Bluetooth HW/SW information
ro.bt.chipset	= Broadcom BCM4329-B1
ro.bt.stack	= Broadcom BTL-A
ro.bt.stack.version	= 2.0.50.032
#0x10000010010100101000011 represent bt profile list
ro.bt.profiles	= 4270403
# Properties of BTLA stack
service.brcm.bt.activation = 0
service.brcm.bt.srv_active = 0
service.brcm.bt.hcid_active = 0
service.brcm.bt.btld = 0
service.brcm.bt.btld_pid = 0
service.brcm.bt.avrcp_pass_thru = 0
service.brcm.bt.avrcp_toggle = 1
service.brcm.bt.local_name =
#Welly_Fang
ro.htc.device.slot1 = NV
# Following property will be reference by Settings.
ro.product.processor = 1.2 GHz dual core
ro.product.ram = 1GB
ro.product.display_resolution = 4.3 inch qHD resolution
ro.product.main_camera = 5M * 2
ro.product.front_camera = 1.3M
ro.product.bluetooth = 3.0
ro.product.wifi = 802.11 b/g/n
# For opensense sdk
ro.htc.common.version = 3.0.0.0
# Properties for supporting framework features
ro.htc.framework.screencapture = true
# For QC perf binary hooks
# src:vendor/qcom/proprietary/android-perf/release/lib/<CPU arch>/libqc-opt.so
ro.vendor.extension_library=/system/lib/libqc-opt.so
# ADDITIONAL_BUILD_PROPERTIES
ro.setupwizard.mode=OPTIONAL
ro.config.ringtone=QuietlyBrilliant.mp3
ro.config.notification_sound=Zeta.mp3
ro.config.alarm_alert=NewDay.mp3
ro.config.cal_notification=Epsilon.mp3
ro.config.msg_notification=Gamma.mp3
drm.service.enabled=true
ro.com.google.gmsversion=4.0_r2
media.a1026.nsForVoiceRec=0
htc.audio.alt.enable=1
htc.audio.hac.enable=1
lpa.decode=true
lpa.use-stagefright=true
htc.audio.q6.topology=0
ro.setupwizard.enterprise_mode=1
dalvik.vm.dexopt-flags=m=y
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
Thanks! Now how easy would this be to modify so I can download GTA3? I had a modified prop on my Triumph that I believe told the Play Store that my phone was a Thunderbird.
Go to the Evo 3D forums and search if not kindly ask for an unmodified build prop
I went to reddit and asked for an Evo 3D build.prop. Someone sent me one they're using on an ICS ROM that's based on the Evo V's ROM:
Code:
ro.com.google.clientidbase=android-sprint-us
ro.com.google.clientidbase.yt=android-sprint-us
ro.com.google.clientidbase.am=android-sprint-us
ro.com.google.clientidbase.vs=android-sprint-us
ro.com.google.clientidbase.gmm=android-sprint-us
ro.com.google.clientidbase.ms=android-sprint-us
ro.tether.denied=false
ro.wifi.hotspotUI=1
ro.usb.tetheringUI=1
ro.bt.tetheringUI=1
ro.product.brand=Sprint
gsm.sim.operator.alpha=Sprint
gsm.operator.alpha=Sprint
ro.cdma.home.operator.alpha=Sprint
ro.cdma.home.operator.numeric=310120
gsm.sim.operator.numeric=310120
gsm.operator.numeric=310120
ro.da1.enable=false
ro.da1.method=false
ro.aa.rid=83
ro.cwkey=SPCS_002
ro.aa.skulist=652
ro.aa.mainsku=652
ro.aa.taskid=259069
ro.build.id=IML74K
ro.build.version.incremental=372137.1
ro.build.date=五  4月 27 20:14:56 CST 2012
ro.build.date.utc=1335528896
ro.build.type=user
ro.build.user=
ro.wifi.channels=
ro.build.description=1.13.652.2_R2 CL372137 release-keys
ro.build.fingerprint=sprint/htc_shooter/shooter:4.0.3/IML74K/372137.1:user/release-keys
ro.build.project=Shooter_ICS_35_S:259069
ro.product.version=MeanROM ICS v2.2
debug.fb.rgb565 = 0
debug.sf.hw = 1
windowsmgr.max_events_per_sec=240
ro.kernel.android.checkjni=0
ro.ext4fs = 1
#Welly_Fang
# For opensense sdk
lpa.decode=true
dalvik.vm.verify-bytecode = false
dalvik.vm.dexopt-flags=v=n,o=v
net.bt.name=Android
# Tweaks
persist.adb.notify=0
debug.performance.tuning=1
video.accelerate.hw=1
ro.ril.disable.power.collapse=0
pm.sleep_mode=1
ro.config.htc.nocheckin=1
ro.config.nocheckin=1
ro.ril.hsxpa=3
ro.ril.gprsclass=32
ro.ril.hep=1
ro.ril.hsdpa.category=28
ro.ril.enable.3g.prefix=1
ro.ril.htcmaskw1.bitmask=4294967295
ro.ril.htcmaskw1=268449905
ro.ril.hsupa.category=9
ro.ril.def.agps.mode=2
ro.ril.def.agps.feature=1
ro.ril.enable.sdr=1
ro.ril.enable.gea3=1
ro.ril.enable.fd.plmn.prefix=23402,23410,23411
ro.ril.enable.a52=0
ro.ril.enable.a53=1
ro.ril.enable.dtm=1
So since I don't know much about editing Android system files, would changing the "ro.product.model=PG86100" be all we need to change?
Thanks.
Thanks for the build.prop from the evo 3d. Changed these settings:
from original:
Changed it in both locations of build.prop(not sure if required)
Now I can play Six Guns without it saying my device is incompatible.
Screenshot after extra 200+ MB downloaded...
from original:
Awesome! Thanks so much!
Now I just need to root this sucker tomorrow and edit my prop file. Can't wait to try out GTA3. It ran poorly on my Triumph, but I imagine the Evo V can handle it quite well.
And there's Max Payne to look forward to on Thursday. :)
edit:
Hmm, it didn't seem to work for me. I'm downloading NOVA 3 to see if it works for that. But GTA3 is still listed incompatible. Maybe I changed the wrong values?
Unmonstro I'm not sure if you own GTA3, but could you see if it's listed as compatible in the Play Store now?
Thanks!
edit #2:
Ah, now I see that it isn't even compatible with the Evo 3D. So should I set my build.prop to something else? I know almost every game was compatible with the Thunderbolt prop I was using with my Triumph. Is there any negative to setting your phone to something else?
Thanks!
Well, I've been able to restore my GTA3 backup that I had from my Triumph's Titanium Backup, but I still can't get the Play Store to see my phone as compatible.
Can anyone help with modifying the build.prop? I'd like to be able to make it as universal as possible.
Thanks!
[FONT=&quot]1. Get Root Explorer ($3.99) from [/FONT][FONT=&quot]Amazon[/FONT][FONT=&quot] Appstore [/FONT][FONT=&quot]here[/FONT][FONT=&quot] or from Android market [/FONT][FONT=&quot]here[/FONT][FONT=&quot]. I've tried several other apps (File Manager, Astro, Linda) but for some reason they won't work.
2. Open Root explorer. Go to 'system'
3. Click to Mount as r/w.
4. Long press build.prop file. When the menu pops up click "open in text editor".
5. Change the following: [/FONT]
[FONT=&quot]ro.product.model=Nexus S
ro.product.brand=Samsung
ro.product.name=sodu
ro.product.device=crespo[/FONT]
[FONT=&quot]6. Hit back and it will ask to save. Hit save.
7. Click to Mount as r/o (just to be on safe side).
7. Reboot the device and you are done![/FONT]
[FONT=&quot] [/FONT]
[FONT=&quot]Galaxy Nexus [/FONT]
# begin build properties [FONT=&quot]# autogenerated by buildinfo.sh[/FONT]
[FONT=&quot]ro.build.id=ICL53F[/FONT]
[FONT=&quot]ro.build.display.id=ICL53F[/FONT]
[FONT=&quot]ro.build.version.incremental=235179[/FONT]
[FONT=&quot]ro.build.version.sdk=14[/FONT]
[FONT=&quot]ro.build.version.codename=REL[/FONT]
[FONT=&quot]ro.build.version.release=4.0.2[/FONT]
[FONT=&quot]ro.build.date=Thu Dec 8 01:28:56 UTC 2011[/FONT]
[FONT=&quot]ro.build.date.utc=1323307736[/FONT]
[FONT=&quot]ro.build.type=user[/FONT]
[FONT=&quot]ro.build.user=android-build[/FONT]
[FONT=&quot]ro.build.host=vpbs6.mtv.corp.google.com[/FONT]
[FONT=&quot]ro.build.tags=release-keys[/FONT]
[FONT=&quot]ro.product.model=Galaxy Nexus[/FONT]
[FONT=&quot]ro.product.brand=google[/FONT]
[FONT=&quot]ro.product.name=mysid[/FONT]
[FONT=&quot]ro.product.device=toro[/FONT]
[FONT=&quot]ro.product.board=tuna[/FONT]
[FONT=&quot]ro.product.cpu.abi=armeabi-v7a[/FONT]
[FONT=&quot]ro.product.cpu.abi2=armeabi[/FONT]
[FONT=&quot]ro.product.manufacturer=samsung[/FONT]
[FONT=&quot]ro.product.locale.language=en[/FONT]
[FONT=&quot]ro.product.locale.region=US[/FONT]
[FONT=&quot]ro.wifi.channels=[/FONT]
[FONT=&quot]ro.board.platform=omap4[/FONT]
[FONT=&quot]# ro.build.product is obsolete; use ro.product.device[/FONT]
[FONT=&quot]ro.build.product=toro[/FONT]
[FONT=&quot]# Do not try to parse ro.build.description or .fingerprint[/FONT]
[FONT=&quot]ro.build.description=mysid-user 4.0.2 ICL53F 235179 release-keys[/FONT]
[FONT=&quot]ro.build.fingerprint=google/mysid/toro:4.0.2/ICL53F/235179:user/release-keys[/FONT]
[FONT=&quot]ro.build.characteristics=nosdcard[/FONT]
[FONT=&quot]# end build properties[/FONT]
[FONT=&quot]#[/FONT]
[FONT=&quot]# system.prop for toro[/FONT]
If this works then you are awesome! (heck, you're even awesome for trying to help even if it doesn't work)
I've been doing countless Google searches and forum scrounging to try and find settings that would work. I'll give this a shot and report back.
From my searching I thought that the line starting with "ro.build.fingerprint" was important as well. Or can I leave that as it is?
You can also give ES File Explorer a try. It's free and I have never had an issue using that instead of root explorer.
It didn't seem to work, at least not with these settings:
The market still sees my phone as HTCEVOV4G
Should I try the Galaxy Nexus? I don't think it'll make a difference.
edit:
Tried the Galaxy Nexus, still no difference.
Should I try changing this as well:
Will it cause any harm?
are you guys clearing cache and dalvik cache after editing the build.prop. it may help. When I changed mine to get links in sms to open play store or youtube I had to clear my caches through recovery. Just a thought give it a try.
