how can we remove the stock dialer and install a new dialer ( ported from samsung or any new app which does not use stock dialer)..? because its becoming difficult to dial no. in stock one.. any help is highly appreciated ..
Removal of pre-installed apps is usually only possible if you root - it is also worth noting that some pre-installed apps are essential for your phone to work. Have you not tried to download a third party dialer app from Google Play? Usually, on installing a new one, you should get an option to change the default app to whichever you prefer
