eclipsed039
I'm on cm nightly 41813 and was wondering if I can get the stock lock screen back?
I'm not sure I understand the question. Which stock lock screen are you referring to? As far as I'm aware, CM10.1 uses an ASOP lockscreen.
That would be google search you need to have added IIRC. It may not be part of the gapps package so you may need to download it manually. You also need to not have any pin lock activated to use it.
