I am not aware if any of you guys are having this problem, I updated to ICS and absolutely love it, but I noticed that Handcent which I have been using for a few years now on many a phone is having problems sending messages half the time, It random with random people so I cant pin down one situation that makes it stop.
If I use the stock messaging app then my text go though first time all the time, but I dont get notifications anymore though the stock app.
And yes I have gone into settings and I have it turned on it should be notifying me with a alarm sound and vibrate.
If I use handcent I always get the popup and the notification in the notification bar and sound+vibrate works just fine. Turn that off and start to use the stock app again... No sound+vibrate... Anyone else have an idea?
