Lucidot
OK. I am using SafeStrap 3. Made a backup of stock rom, created rom slot, did complete wipe of on stock slot and rom slot. Installed rom in slot and ran it for a bit, but it was missing some things that I use so I decided to go back to stock. So I activated the stock, did another wipe and did a restore. When the phone booted everything on the screen was just a garbled mess and it only took up about an inch or less of the screen. So I booted back into recovery and did another factory reset without doing a restore and got the same result.
So right now I had to install another rom in the slot and it runs fine, but I want to go back to the stock rom. Am I screwed??
