Root Stock Rom M865C
raymealer
Member
Does anyone have a stock backup they made from there phone they
Could post for me I had an SD card failure
I sure would appreciate any help
Thanks in advance
Straight talk m865c
What carrier and device do you own? I can move this to your devices root section where the members there can assist. :)
Ill never buy anothe one of these phones... Pulled a noob and formatted the sd card with my nandroid, now, cant find the stock rom anywhere...
Huawei site is no help. Probably cant find it because its not worth owning... Just my guess..
Heres a link to the stock, rooted, 2.3.6 rom.... Thanks to MCDIETZ at XDA FORUMS.
This is a nandroid backup. Unzip, place folder on sd card in /clockworkmod/backups
May need to delete the nandroid.md5 file, then create a new file with that exact name. I used root explorer to do that. This will need to be done if you get a md5 checksum error when restoring.
START UP IN CLOCKWORK, AND RESTORE LIKE NORMAL.
THIS IS FOR THE STRAIGHT TALK M865C ASCEND II.
https://www.dropbox.com/s/ydaxwaa7pxvo8z3/2012-11-02-m865c-stock.zip
