(Stock ROM) Updated SP tool flashable ROM
drdogautam
Download the ziped file and unzip it...
then use latest SP Flash tool and Load scatter file
and then click on "Firmware>Upgrade" in SP tool...
now connect your mobile in switched off mode to PC....
wait for completion of the procedure....
Green Circle Appears and say download complete....
Now remove ur mobile from PC and switch it ON by Power Button...
VIOLA u are on updated Original Stock Q700 ROM (Which is Official ROM of XOLO) with all Warranty Cover.
Download link : https://adf.ly/YAkb1
Press Thanks, If I helped You. :)
