Stopping data after inactivity
jkoch2272
I am coming from a DX which had a setting to cut off data after a certain time of inactivity. Is anyone aware of a setting on the GS3? I haven't been able to find one yet...
Thanks
Also coming from the DX this is a feature I miss. Mine was set to disable data after 15 min of inactivity. I have not found a similar feature on the sgs3.
You could use something like Juice Defender. Its a battery monitoring app which has the ability to turn off data connections when the phone goes to sleep and turns the data on again when the phone is woken up. This is the only thing I can think of which might be of some use.
