Well, one of 2 ways.
With your file browser, which is called My Files, I think...sorry, I can't remember exactly because I'm on another rom.
Or, via your computer when your device is plugged in.
I think what he's saying is that Storage provides a detailed breakdown of the internal storage used but for the extSD card it only shows the total capacity and the free space available, with no detailed breakdown.
A really good app is DiskUsage, which gives you a visual portrayal of the space used - it's like WinDirStat for windows. You can see at a glance the files and folders that are taking up the most space.
Alternatively use a file manager app as others have suggested. ES File Explorer is very good.
The problem with file managers/explorers is that they don't tell you at a glance the size of folders in a similar way that Storage in Settings shows you the space used by specific file types.
