Storage Issues (Internal and SD) Help much appreciated!
  • Start date Start date
A
Android Question
Guest
Hello,
So basically a week ago a received my new elephone P8 android phone.
(Supposedly Rooted however wasn't on root checker)
16gb phone storage
32gb SD previously been on a blackberry and not formatted but still worked for both media and apps.
it worked fine as a phone and seemed like everything was ok however after a couple of app downloads it came up with the message insufficient space.
so had a good google, got a cleaner app for cashe files, worked to a certain extent but some apps have to be on the phone storage so couldn't download then move.
i checked the storage space and saw i still had 12gb of phone storage (28gb on sd) however it seemed in the cleaner app i only had 1.5 gb of storage for apps??
So the QUESTION is how do allow access to all the phones storage to my apps?
which i clearly have.
I have also rooted since to try the app market fix and Link2SD however it managed to unroot itself maybe on a phone reset? i did root it again though but still not done much.
Also half my apps keep disappearing from my home screens so i have random spaces. i think this is on phone restarting aswell.
Do i need to partition my phone storage more. or is it a ROM Problem?
Any help or just to explain it a little would be appreciated!
Thanks Lewis
