Help Storage question S5 Neo
smallclone
Hi. Samsung S5 Neo.
I'm confused about my space. my storage says I have 10.89GB out of 16GB internal storage. But on Xplore the disk map says I have only used 2.86GB. Which is right? Thanks
This is a simpler storage map of my Lenovo K3 Note
Total internal memory : 16gb
OS reserved space : 4.81gb
User usable space : 12.12gb
User used space : 7.31gb
You should notice the 11.19gb figures instead of 12.12gb mentioned above, so almost 1gb has disappeared, right?
There is no way you could have an exact result like 2 + 2 = 4 because apps generate cache files and update data files all the time while running.
