nieltab
Hi all,
I discovered today that many files were stored on the internal memory instead of the sd card. So I cut/pasted all my images on my sd card and changed the save path from my camera app to this same folder.
Now there was still a lot of memory used in following path android --> data --> com.cooliris.media --> cashe --> hires-image-cashe (which seems to be in my galary app). The files it contains are ending with .cashe and there are 1766 files in it (118MB).
How can I get all of this stuff on my sdcard with everything working as it should? I just want as much as possible on my sd card.
Thnx!
Thnx!
