Help storage space not adding up correctly...
Hi, i am trying to fix my issue without reseting etc.
Phone is an LG Motion ms770
The issue is that in my "storage" page the count doesnt add up correctly,
for example if all used space is added up, it doesn't equate what the phone says is used up, it displays a higher used count than is actually used and the amount showing as available space is gigs lower than where it should be.
I added it up and the total used should be 2.45 used out of 5.5 gigs, but yet it says I only have 495mb available instead of almost 3gigs.
Last time it did that i did a software update and it corrected the count, but now there is no update available so I cant use that method anymore,
and then there is the fact that the problem was not permanently corrected, it has re-occured after having been corrected with the update
Hope you can help, I really would rather not have to do a reset and lose all pics etc
Thanks alot
