B
bobojimo
Guest
Hello recently I purchased a Samsung galaxy ace 2 I updated it to jelly bean and installed some apps and games on it from the play store. Everything was going fine until I decided to transfer some APKS off my computer running Win XP at first it worked successfully. The second time I transferred more APKS to the phone the computer just wouldn't show any files under the directory SD card and the phone doesn't show any files on it either. When I tried to create new folders or copy files around it would through up an error message or just take forever to complete the desired task. I relies that the card is probably corrupted this doesn't concern me as there is nothing to important on it but I would like to know what the problem is and how to avoid it in the future. Another problem I have is that the computer reads that the memory under the phone directory as completely full while the phone tells me the complete opposite.
Thanks
Thanks
