Help Straight talk APN ATT help!
Amaeloeze
I'm not able to use any data on my nexus 4 because my apn is not set up. I don't know how to set it up i've been looking and trying things but nothing is working can someone please help?! thanks
That poster was incorrect about needing two different settings. your phone can only use one at a time.
follow this guide:
How to set up the right APN on your Nexus 4 | Android Central
except leave the proxy field blank. You don't need it, and it will probably slow you down slightly.
it's that simple, just those 5 or 6 settings in the APN, reboot, then you're ready to go.
This is what I have configured on my and my wife's nexus 4 handsets. MMS has been working for us.
# Straight Talk #
APN: att.mvno
MMSC: http://mmsc.cingular.com
MMS proxy: 66.209.11.33
MCC: 310
MNC: 410
APN Type: default,supl,mms
Protocol: IPv4
Roam Prot: IPv4
-SF
# Straight Talk #
APN: att.mvno
MMS proxy: 66.209.11.33:80 (mms2.tracfone.com)
with Port: 80
MCC: 310
MNC: 410
APN Type: default,supl,mms,hipri
Protocol: IPv4
Roam Prot: IPv4
-SF
Because ST APN's seem to be fickle, especially with MMS, I've included what works for me. This DOESN'T mean the above settings won't work so try them first. I believe the numbers 66.209.11.33 = mms2.tracfone.com. I do not know if the port is necessary, but I have it. Note that :80 after the proxy numbers will work. I added the "hipri" when I was having problems with mms. It could be coincidental that mms started working after that. When I am on wifi, I usually have to turn it off for mms to send.
I just set up my Nexus 4 using the info from the straight talk sim support page:
(go to this link and click on "Phone Programming")
1. CREATE A NEW APN (ACCESS POINT NAME). ENTER ONLY THE SETTINGS LISTED BELOW:
FIELD SETTINGS
APN: tfdata
PORT: 80
MMSC: http://mms-tf.net
MMS PROXY: mms3.tracfone.com
MMS PORT: 80
2. SELECT THE APN YOU JUST CREATED.
3. DELETE THE OLD APN FROM YOUR PHONE IF POSSIBLE.
It is working perfectly on my phone.
FIELDSETTINGS
APN: tfdata
PORT: 80
MMS PORT: 80
Just tried these settings today twice and was never able to get then to work. Back to the original att.mvno settings.
