I don't think you're actually using both AT&T and Sprint's towers. Sprint is a CDMA carrier while AT&T is a GSM carrier and the technologies aren't compatible with each other. If you bought the device through Straight Talk, then it's using Sprint's towers. If you brought your own device to Straight Talk, you're using either AT&T or T-Mobile. Since Verizon is a CDMA carrier, there's no way to transfer your service from Sprint's towers to Verizon's. ST sells a couple of phones that run on Verizon's towers, but the GS3 isn't one of them. They also allow you to bring your own Verizon 3G only phone and they can flash that and get it to work with them as well. However since the GS3 uses LTE, it is not compatible with that program.
Not really, CDMA is a closed sourced/locked down network where devices cannot be transfered between similar CDMA networks easily. Most method are illegal, and the only legal way would require you to buy another phone anyways. Plus if you did get it to work, you would only have 3g and not LTE due to radio frequency compatibility.
LTE I don't really care about. I just would like my phone to work when I travel north or go Skiing or on the lake. Making and getting calls and text. I could switch to Verizon up there, then while in Sprint area it can stay on that. Can this be done?
I just hate it saying No service.
LoL
Darn, what can I due to get this phone to work on Straight Talk and ping on Verizon tower? Or what if I pick up a unlocked Verizon one and put it on Straight talk?
What is the code to open the modem dialer on a Straight Talk Galaxy S3 ? I tired ##3424# and +#7284# and they didn't work..
