Straight Talk Nexus 5 Usage
Thank you! Are you on AT&T towers?
Yep. I tried to find an AT&T SIM at my local Walmart(s), but struck out all over town when I checked online. I went ahead and ordered the AT&T Micro SIM from their website and sprung for overnight delivery so that it arrived yesterday (same as the N5). I had a bit of a hiccup when I tried to activate online (see post above), but it got resolved pretty quickly. Only took about 30 minutes to port my number from Verizon.
~Gary
I've been with Sprint for 12+ years and I'm switching thanks to the Nexus 5.
I ordered the free T Mobile sim and plan to give it a shot for atleast a month. I probably won't use the entire 100 minutes or 5g of 4g.
If I'm not happy, I'll give Straight Talk a shot. Options are very nice right now.
Which begs the question, anyone in and around Denver and the burbs have experience with T Mobile or Straight Talk?
My wife is still on Sprint until next summer, but I'll happily pay the ETF once I figure out which service works best for us.
Can you post a link to that specific sim card/plan? I was looking everywhere on the T-mo website for the $30/mo 100minutes, unlimited text, & 5g of 4g but it kept only showing me the $50, $60, and $70/mo options that come with more minutes and less data. And also, would you be getting 4G with the T-mo prepaid sim? I would love to pay $30/mo for what I actually use, instead of $45 even though ST is unlimited.
Please & thank you!!!
I've tried to set up my AT&T ST sim using these settings and its not working for me... help??
Did you port a number, and is the port completed? Can you make and receive any calls? Do you have any data at all?
Thanks, Techrider 62. Your settings worked for me. I'm using a Nexus 5 (came today!) with Straight Talk, and your pointers got me going just fine, with data.
Working here just fine.Here are my settings
FIELD SETTINGS
NAME straight talk
APN tfdata
MMSC: http://mms-tf.net
MMS PROXY 66.209.11.33
MMS PORT 80
Auth type PAP
APN Type default,supl,mms
ok, first time using ST and first time having to manually mess with APN settings. N5 and ATT ST sim.
These are my full settings currently (I have tried a few now, including those listed in this thread)
APN: tfdata
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
MMSC:
MMS Proxy: mms3.tracfone.com
MMS Port: 80
MCC: 310
MNC: 410
Authentication Type: PAP
APN Type: default,supl,mms
APN Protocol: IPv4
APN Roaming Protocol: IPv4
APN enabled
Bearer: unspecified
MVNO type: none
MVNO value: not set
Whenever I set these, I delete the old APN settings and power cycle and still no data (calls and text work). I appreciate any help :)
APN: tfdata
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
MMSC:
MMS Port: 80
MCC: 310
MNC: 410
APN Protocol: IPv4
APN enabled
Bearer: unspecified
MVNO type: none
MVNO value: not set
I just activated with ST on the N5 and I'm fully working. I compared my settings to yours and here is what I have different:
Authentication type: Not set (you have PAP)
APN Type: Not set (you have default,supl,mms
Those are the only differences I saw between what I have and what you have above. Let us know if this helps. I'd power cycle the phone after you make any changes, just to be safe.
~Gary
~Gary
Thanks. I removed the auth type and APN type (I didn't have them originally but was tinkering and added those). It still wasn't working. However, I got through to ST live chat and they fixed something on their end and I'm in business now! Thanks anyway for the help. Came from a DX2 and 3G to N5 on LTE. Wow!
Glad to hear you got it working. FYI - be careful running speedtests on LTE. I think I ran 3 tests and then happened to check my data usage. In two days I've used 198MB of data, and the speedtest app accounts for 150MB of that data. DOH!
So be careful - the last thing you want to do is use up all your data for the month drooling over those fast LTE speedtest results!
~Gary
It's only on their prepaid site to which they removed links to from their website. If you google T-Mobile prepaid plans, it should last it somewhere in the middle of the page.
Okay ty, I found it. So I iust order a SIM and then select the plan when I recieve and activate it?
So can anyone confirm that straight talk with AT&T sim is actually the exact same service as going with AT&T? I am thinking of switching off of Verizon and I know AT&T service is good.
I'm getting speed like
21.40 down 12.04 up
21.93 down 5.21 up
12.53 down 3.40 up
11.15 down 7.94 up
Depending on where i'm at
Just did 2 tests on on N5 and Straight Talk, it shows the LTE letters and 3 Bars.
18 down 4 up
14 down 4 up
Inside my house. Haven't tested outside yet.
but I just want to post my APN settings and it won't let me post links until my second post, so it seemed like the lesser of two evils, the alternative being someone else having to call straight talk and wrestle this out of them
~Gary
My N5 is working on LTE in Salt Lake City right now. My APN settings are as follows:
APN: tfdata
Port: 80
MMSC: http://mms-cf.net
MMS Port: 80
Getting those out of the ST phone support was like pulling teeth - I practically had to explain the concept of APN settings
Can you share a little more on the eBay multiple month ST cards? Trying to find 6 & 12 month options.
Straight Talk $45 $135 $270 Unlimited Top Up Refill 1 3 6 Month 90 180 Days Card | eBay
straight talk 6 month | eBay
Here is the best I could find right now. I just check them every few months and when the price goes down renew early. Whenever you add a renewal the extra months are added onto your existing plan. You will get a text confirming and then you can verify on straight talks website under the my account area. I would just purchase from the trusted sellers on eBay with 90% and up feedback and been members for at least a few years. Best part is no taxes or fees added on top so that really sweetens the deal for me. ;-)
It sounds very encouraging and almost too good to be true for ST with LTE now!
But over at ST forum, I saw some guys complaining on spotty, unstable data connection compared to ATT, Tmo. How's the reliability of data connection on ST?
I've not experienced bad or spotty data connection. I live about half hour south of Birmingham, AL and get solid LTE at home and work. I never use much more than 1 or 2GB's a month so haven't ever been throttled but I imagine that would be painful if you plan on trying to tether or just stream YouTube out Hulu a lot. Good luck!
