Root Straight to SD Card
Rinju
So I recently rooted my phone using the new one click root method & I also edited my build.prop to enable the Move to SD option. My question is with larger files from the play store is it possible for those apps to download & install straight to SD card instead of straight to the external? If there is a way could someone possibly tell me step by step since I am still fairly new to this whole rooting process.
You can try using rom tb pro it has a feature that allows you to select where you want apps automatically stored. I don't know for sure if it works though..
EDIT: Doesn't work, it gives insufficient storage error message.
