Help Strange battery readings?
landovr
So this morning I noticed that my voltage on my battery was lower than normal. The battery meter said 100% but the voltage was 4045mv and it is normally 4206mv when fully charged. As I was using it the voltage was going up and down from 4045 to 4120. I checked with the battery meter widget I downloaded from the market and the HTC battery widget and they both showed the same voltage as this was happening. Is this the sign of a failing battery after only three months???
