Root Strange Bootloop
AlexRayquaza
As the title says,im bootlooped.
Not sure what caused it.
i tried flashing a rom but still the same.
the dmesg has a wierd error that says
init: 920 exited
then the number just keeps raising.
What do you guys recommened me do to get back to normal?
init: 920 exited
have you tried going to stock maybe that'll work
Use Odin to flash back using the .tar You'll be on 4.0 because I don't think there is an Odin tar for jb but that's an easy fix. I've been bootlooped before and that's worked for me
That .tar is just the system.img so he would also need to flash the ics kernel.
This goes back to what shabby was saying about us needing to map all the partitions in the phone (and back them up) so that we could have a FULL Odin restore.
So basically im screwed?
Not necessarily. All we have to do is map the partitions. You don't need an unrooted image. If we could pull the partitions from a rooted phone, figure out what they are, and pack them for use with Odin you'd be fine.
I'm just not sure how to go about mapping them. Does anyone know how to go about it?
Edit- I'm petty sure you have to view them with a hex editor. Which I'm in the process of doing
