Help Strange charging problem
roa
I tried to charge my updated phone (baseband I7500XXIG8) on both car lighter charger and third party micro usb charger. When connected, the phone did not recognize that it is being charged at all - but after a while I noticed that the battery widget did show more percentage than before. Even after disconnecting, the percentage varied up and down few percent - from 80% to 85%, then (after heavy usage of 3G, wlan, gps...) jumped to 50%. The rest of discharge was also erratic, i.e. in no way was it smooth discharge curve.
I attribute this to firmware - I don't believe that my chargers cannot supply enough mA or too low voltage and that the phone does not detect it;
After discharging the phone completely (it shut down at 1%, interesting it did not want to turn on 3G under 5%) I charged it with the original charger. After ~20 minutes of charging the battery was on 55%, isn't it a bit too fast?
I'll try to cycle it few times now.
I also guess that this kind of "uncontrolled" charging can at least uncalibrate the battery if not even damage it...
This is totally unacceptable given the already bad or erratic power performance of galaxy. Not being able to charge it the car makes it unusable.
What do you think? I never heard of such problems with other microusb-charged devices...
I purchased an aftermarket charger not long after I got my G1. It displayed very erratic behavior while I used it. After discontinuing use and going with strictly USB and my OEM charger my G1 went back to normal. Don't know if your situation is related but I thought I'd mention it.
I had the same using my old iphone charger with the galaxy sync cable (I used that because I have a USB extension cable so i can easily use the phone while its charging). It didnt recognise it was being charged either.
