Strange glitches
bigbdroid
Hey y'all.
My LG Stylo 4 (LM-Q710TS) keeps clutching out. Small but very annoying glitches.
  • Wallpaper resets to default
  • Looping home screen setting keeps turning off
  • Keyboard won't stay onscreen very long.
  • Internet blinks(?)
  • Screen blinks
Basically my whole phone glitches out and resets little things.
Any ideas as to why this might be happening?
With all being said and done if I have to replace this phone, can someone recommend a good phone with at least the following features.
  1. FM tuner
  2. Built-in casting
  3. MHL capable
  4. Easy to root with need of PC
I prefer LG. But my budget is very low. And it's gotta be TMO compatible. Just sucks, because I've only had this phone for 3-4 months.
And No dice on factory reset. Did it twice
Are you by any chance using a third party launcher, or other apps such as calling apps, messaging apps, or any other that runs continuously?
I ask because on a low performance device there are some apps that use way too much power for such devices.
Case in point, I had a phone with 1GB of RAM, and I really liked Apex Launcher.
The phone had most if not all of the symptoms you describe, even if I got rid of almost all my user apps.
I later discovered that while Apex Laucher itsrlf only uses about 30MB of RAM, the Google Analytics built into it used a whopping 200MB of RAM all the time!
Together, that makes about 25% of the memory used.
Now add whatever the system needed to work.
No wonder that poor phone was acting up!
So, I ditched that launcher, and now look for apps that do not have Google Analytics built into them.
It makes the device much happier, I am much happier, and Google can get bent for all I care.
