Help Strange IQ notification on Lock Screen
Hi All,
I'm new to the forum, I did some research but I wasn't able to find an answer... does anybody know what the small IQ on the notification bar means (upper left corner)? It has been showing there in the last days, but seems not to be connected to apps (at least not that I've been able to find), and has no additional notification when scrolling down...
Thanks a lot for your help
****Update****
Could it be something related with the roaming and services (callerID,...)? Does anybody experience the same?
An icon should have an entry in the notification pulldown...Very odd
A bit of googling around
Do you happen to own a Garmin Smart Watch?
https://support.smartthings.com/hc/en-us/articles/115001815503-Garmin-Watch
https://www.programmableweb.com/new...uth-to-wearables/sponsored-content/2016/12/05
Years ago there used to be a nasty, carrier/manufacturer installed, borderline spyware/"middleware", called CarrierIQ. It ran invisible in the background - never had an icon or notification that I am aware of. It was basically banned in the U.S. and resulted in a class action lawsuit
Thanks for the input, i do not have a Garmin SW, i found that as well between the results on Google.
I went through process check and all the standard investigation process, but I start thinking this could be a weird way of the Telenor Carrier Provider in Sweden to identify themself (normally in that position there is Vodafone witten when i'm home)... It's the only thing that popped up on my mind...
