Strange mobile data usage
Why can't I see how much data these apps are using? to me that all appear to be apps that would be using a very nominal amount. Is this something to be concerned about?
You can turn off all the background mobile data easy, just head over to the app and switch them off in the third choice below each one, that will be pretty chill, and you will not worry about that.
