Help Stream GPS data
I have 2 android phones.
Machine 1 has a good GPS system - and rarely if ever drops the signal. But it has a small screen and so is not to good for mapping work - especially with my ageing eyesight.
Machine 2 has a good large screen, but often seems to loose the GPS signal and then takes ages to recover it again.
So - is there a solution where I use the GPS data from m/c1 and stream it with BT to m/c2 ??
Any suggestions as to how this can be done please ?
Ta
David
Have a look at this resource on sharing device GPS data. Let us know your thoughts and if this seems to be a reliable location to resolve your issue.
Also, try @svim post response and see how that pans out.
Thanks - yes I have that installed. It works for a while and then goes back to being a pain again.
Thanks for the help
David
