Street view slow rendering
Anyone else have a very unresponsive street view on the N5 ?
When I check out maps and then go into street view when I find a road I want to look at houses on for instance it seems to take an age to render the clear image of the street.
I am having to stare at the fuzzy image for over half a minute while piece by piece each little section clears up.
So annoying it even does it on WiFi connection
Well there has to be something wrong with the phone because on WiFi and Vodafone H+ its dreadfully slow and if you move up the street a tad then you have to wait all over again aaarrrgggg.
Also the little man marker you could slide up the street into the place you want to go that was dropped in favour of an arrow was a bad decision I think.
The latest version with the arrows for navigation are very unresponsive compared with that little yellow dude.
That's Vodafone for you. Work S3 Internet is appallingly slow compared to EE. Even worse than O2!
My old S2 is instant street view loads and it's clear right away same on my mates s4.
I can't see how a Google phone with such a mighty processor could be slower with Google software.
It makes street view non use able really. Pfff.
