Dkelz313
I've been trying to download this widget, and every time I do it jus disappears from the notification bar and doesn't download. It's the "quick record" widget, when u go to add a widget to the home screen, in the widget window, click "get more widgets" and its the 8th one down. Has anyone else had this problem ? Or does the widget work for you ?
