nspriggs
Member
I let the battery die on my tablet a few days ago, so i plugged it in and let it charge for a bit. I tried to power it on, and it powered off immediately upon booting because, i assume, the battery was too low. So i let if charge more, and now when i turn it on, it will boot all the way up to the lockscreen, then reboot in <3 seconds. Every time. There's nothing i can do to stop it. I never flashed anything, or even rooted my tablet.
Also, when i try to boot into recovery, it just shows an android on his back with a red exclamation mark over him and the words "no command".
Has anyine had this problem?is tgere a simple way to fix it? Is there a not so simple way to fix it? Because im okay with that as well
