Help Stuck in a loop. Gah!
Can I get a bit of advice?
I was trying to flash to cyanogenmod 7 and it was a little more complicated than I initially thought. I got this little bugger pop up:
Finding update package
How is it looping? Is it stuck at the Samsung logo, or does it display 3 icons (phone, pc, and an exclamation point)?
That is unusual. Normally when a samsung phone loops, it's one of the two I mentioned above. What procedure did you do when trying to flash CM7? Was it the correct version for your device and did the md5 match? If not, it might have been a corrupted download. Redownloading it might be all that you need to do.
Thanks! I'll give it a try and let you know.
It was the correct one. Funny thing though - I re-tried and it worked. Didn't change a thing, but it worked. *shrug* I'm not gonna question it. :)
Cheers!
It's funny how that happens sometimes, wouldn't be the first time I've seen it, and it's even happened once for me.
