Hello I have the same problem as the previouse people here...I have an lg Venice rooted and was using J.C. Rummy tool box pro app to do a backup in the Rom installer portion of the app. I thought I was just backing up something that was already there so no harm...well it asked me to start recovery and I said ok and now it's stuck in android system recovery <3e> and I can't select any of the options. Every time I select an option to reboot or whatever, all the writing goes away and the dead android guy lights up and nothing happens. And if I push the home button again all the choices for reboot and update from adb factory reset and all that just appear again?? Pls help!
I was reading some other problems similar to this with different phones and they say to try booting into download mode but is that right? And if so what then?? Thnx for any help ASAP
