So I tried to SBF back to 340 with this file: : VRZ_MB810_2.3.34_1FF_01.zip, and the transfer said it completed in RSD lite (4.8). Then, it kept bootlooping. Tried to get back into clockwork but whenever I do, it just shows a screen that displays this:
Bootloader
30.04
Battery OK
OK to Program
Transfer Mode:
USB
So what do I do now? I have to try installing the file again? I tried it twice, the first time it didn't work, the second, it did, but it doesn't boot up.
And a question for future reference, why can't I just put the downloaded SBF file on the sd card, then install it from ROM manager? Do I NEED to use RSD lite in order to SBF? It seems like the same process as flashing roms, which would be a lot easier. Anyway thanks and please help as I have no phone
Bootloader
30.04
Battery OK
OK to Program
Transfer Mode:
USB
