Root stuck in clockwork mod recovery
uwho
bought a nexus 7 from castanet in dec last year.
In jan I decided to restore to factory settings.
I haven't been able to use this darn thing since......it is stuck in clockworkmod recovery.
I took it to fix your touch, and they suggested to google & get answers, (as they have a MAC and cant fix ours)
I have been trying for months to figure it out,. such as DL rootkit to install, tred that, anfd then it is saying it cannot find adb..
so what do I do now, I am sooooo confused
I have no idea what that means rukbat.....
now my rootkit is telling me that I need to turn on debugging...however I cant get into home screen b/c there is no data for me to load up.....
Wugs Nexus Root Toolkit.
Nexus Root Toolkit v1.8.2 | WugFresh
Install it, follow the directions of the first button, the driver install.
Once done use NRT’s ”Flash Stock & Unroot" with the soft bricked/bootloop trigger.
Follow the directions carefully to select the proper device and boot into boot loader, then NRT will do the rest and will restore the factory image you selected.
