Hey all, I am in step 2 of the guide and telneting to localhost/23 wont connect? why?
yes
I also went and got a terminal emulator app
now when i go to either root or SU or even just telnet it says permission denied
I did reboot my phone into RC29
So now im really lost
btw i live here in oc as well san cle\mente actually u close ny?
ok I am using justjimpcs guide
and i unzipped the whole folder onto the sd card files from getyourdroidon.com
hers a list of what i got dreaimg.nhb, engineers bootloader jspl signed jf 1.43
i formatted my card to default fat 32 copied the dreaimg ont o it booted into the bootloader loaded it and was in an working os the i dl telnet and thats when it wouldnt let me i
then i got a terminal emulater by that name from apps on market
opened it and no permissinns
wow got it well a little farther but now it doesnt see the img file
so now its updating verifying the update package do i delete it from the sd card after it boots and rename the radio updated file to update as well?
its now rebooted to a white and silvery ANDROID
is it stuck in this? it just scrolls by the word like 4 times then hangs the starts over
how long should i be waiting? it is still at the word andriod before it loads into the os. been about 15 minutes or more
nice got it booted into rc33 i did like you said just did the update to JF adp1.5 oh and i got it! i am getting the radio image now. I REALLY REALLY appreciate your help nooneshereyet Thank you
seems that I have it but the radio ididnt go thruopugh the flash process at all and in theabout phone it says baseband version 62.33.20.08H_ 1.22.12.29 i used image 2.22.19.261 Ill try it again
WOW !! what a marathon session !!
Thanks to NoOneHereYet for all you pateince and persiverence !!!
I continues to amaze me how hard it seems for some to follow the instructions exactly .... and mix or jump steps ...
I just have to use one of my favorite expressions....
" A common mistake that people make when trying to design something completely foolproof, is to underestimate the ingenuity of complete fools."![]()
