PrinceCorwin
Android Expert
Im rooted but not unlocked (no CMW). Everything has been okay until a couple hours ago when I tried to listen to some music (PlayerPro). No music files showed up. I used a file explorer to check my music folder. There were over 500 files there but they all seemed to be corrupted. They had names like "a" or ".,2f" etc. I plugged into my pc and it wouldn't even let me delete the files. When I uninstalled and reinstalled PlayerPro, I saw a message that said "an error has been encountered on your SD card, scanning files. No music files were found. So I did a factory reset. I have been stuck with the "4G LTE" logo for over an hour. Tried to Vol- + Power to reset and the same thing happened. What should I do?
Tried to remove battery, sim, sd also but same thing happened
