So I was messing around with the build.prop file in the system folder to try and get Milk Music to work on my G3, and now I'm stuck in a boot loop. I've only had the phone for a day so I'm pretty angry... It's a T-Mobile LG G3 model LG-D851.
Try and do a factory reset,And see if that fixes it .
Did that, didn't work.
Ok,This is what your going to have to do,It's a lot of work.But your going to have to return to Stock.
[ALL Variants] Update / Restore to Stock you… | LG G3 | XDA Forums
[Guide] Flash stock firmware when boot loop … | LG G2 | XDA Forums
Be sure and remove your sim card 1st,Before you flash.Otherwise it will wipe it too.
Ok, Thanks. Will that guide still work even though it's for a G2?
Yes,Same process,It's how I had to return to stock.
Here is the latest LG G3 firmware:
Download the latest LG G3 stock firmware - flashable TOT | AndroMods
