Hi , I hope there is a simple solution and I am missing something.
I have used Unrevoked v3.32 to install CWM on my Desire and everything seemed to go smoothly. When I boot the phone into recovery mode I can move up and down with the volume keys but when I try and select a function the display just turns off. Pressing the power key turns it back on instantly and I have to remove the battery and then the phone boots up normally.
Any suggestions?
Any suggestions?
