Davros1959
Allwinner A33 chinese tablet
4.4.2 kitkat
stuck on com.android.systemui
Tablet is rooted, USB debugging is enabled
I had issues from the day i bought the device. the seller advised i should root the device and alter the build.prop file to enable certain features.
I made a backup copy of the build.prop file to SDCard, altered the build.prop file and now I am stuck with the device in a constant loop, com.android.systemui has stopped.
I have booted in recovery mode and have attempted wipe and factory reset. This has not made any change.
I have forced a factory reset from PC using ADB. The tablet appears to be resetting and reboots, but cannot change the error.
I have loaded ADK on PC and can see the build.prop bak on the SDCard. How can I copy this file into the root (or system) folder and overwrite the faulty build.prop by using PC?
4.4.2 kitkat
