Help Stuck on FRESH VZ3? OTA Updates wont show up?!?
robles4242
I went with LG flash tool and flashed back to vz3, then after then factory reset it after that.... That brought my fonts back, but OTA updates wont show any available?? Did i do something wrong? Is there a way to enable OTA or force find them with an app? Just figured id ask before i whiped out everything again and flashed another VZ3 to try again.....
They didn't download for me either, I had the updates saved on my sd card so I applied them like that.
My steps were:
Flash tool to zv3
Use Towel root to root
Use flashify to flash twrp
Boot into twrp and install 3 updates
Flash superuser.zip
Only problem i had was not having the boostzone app install. Then again that's not really a problem....
I'm in the same boat, had to go back to ZV3. I flashed ZV6 and the modem but doesn't seem to be all that happy. Does anyone have the ZV4, ZV5, and ZV6 OTAs captured?
SOMEHOW.... after z3.... dsyd later...vz4, rolled in, then one after another, vz5, vz 6... and it kept root every time ( Rooted with One click)
