Fetching https://dl-ssl.google.com/android/repository/addons_list-2.xml
Validate XML
Parse XML
Fetched Add-ons List successfully
Fetching URL: https://dl-ssl.google.com/android/repository/repository-7.xml
Validate XML: https://dl-ssl.google.com/android/repository/repository-7.xml
Parse XML: https://dl-ssl.google.com/android/repository/repository-7.xml
Found SDK Platform Android 1.1, API 2, revision 1 (Obsolete)
Found SDK Platform Android 1.5, API 3, revision 4
Found SDK Platform Android 1.6, API 4, revision 3
Found SDK Platform Android 2.0, API 5, revision 1 (Obsolete)
Found SDK Platform Android 2.0.1, API 6, revision 1 (Obsolete)
Found SDK Platform Android 2.1, API 7, revision 3
Found SDK Platform Android 2.2, API 8, revision 3
Found SDK Platform Android 2.3.1, API 9, revision 2 (Obsolete)
Found SDK Platform Android 2.3.3, API 10, revision 2
Found SDK Platform Android 3.0, API 11, revision 2
Found SDK Platform Android 3.1, API 12, revision 3
Found SDK Platform Android 3.2, API 13, revision 1
Found SDK Platform Android 4.0, API 14, revision 3
Found SDK Platform Android 4.0.3, API 15, revision 3
Found SDK Platform Android 4.1.2, API 16, revision 4
Found SDK Platform Android 4.2.2, API 17, revision 2
Found ARM EABI v7a System Image, Android API 14, revision 2
Found ARM EABI v7a System Image, Android API 15, revision 2
Found ARM EABI v7a System Image, Android API 16, revision 3
Found ARM EABI v7a System Image, Android API 17, revision 2
Found Samples for SDK API 7, revision 1
Found Samples for SDK API 8, revision 1
Found Samples for SDK API 9, revision 1 (Obsolete)
Found Samples for SDK API 10, revision 1
Found Samples for SDK API 11, revision 1
Found Samples for SDK API 12, revision 1
Found Samples for SDK API 13, revision 1
Found Samples for SDK API 14, revision 2
Found Samples for SDK API 15, revision 2
Found Samples for SDK API 16, revision 1
Found Samples for SDK API 17, revision 1
Found Android SDK Platform-tools, revision 16.0.2
Found Android SDK Tools, revision 22
Found Documentation for Android SDK, API 17, revision 2
Found Sources for Android SDK, API 14, revision 1
Found Sources for Android SDK, API 15, revision 2
Found Sources for Android SDK, API 16, revision 2
Found Sources for Android SDK, API 17, revision 1
Fetching URL: https://dl-ssl.google.com/android/repository/addon.xml
Validate XML: https://dl-ssl.google.com/android/repository/addon.xml
Parse XML: https://dl-ssl.google.com/android/repository/addon.xml
Found Google APIs, Android API 3, revision 3
Found Google APIs, Android API 4, revision 2
Found Google APIs, Android API 5, revision 1 (Obsolete)
Found Google APIs, Android API 6, revision 1 (Obsolete)
Found Google APIs, Android API 7, revision 1
Found Google APIs, Android API 8, revision 2
Found Google APIs, Android API 9, revision 2 (Obsolete)
Found Google APIs, Android API 10, revision 2
Found Google APIs, Android API 11, revision 1
Found Google APIs, Android API 12, revision 1
Found Google APIs, Android API 13, revision 1
Found Google APIs, Android API 14, revision 2
Found Google APIs, Android API 15, revision 2
Found Google APIs, Android API 16, revision 3
Found Google TV Addon, Android API 12, revision 2
Found Google TV Addon, Android API 13, revision 1
Found Google APIs, Android API 17, revision 3
Found Google APIs, Android API 18, revision 1
Found Android Support Library, revision 18
Found Android Support Repository, revision 2
Found Google Repository, revision 2
Found Google Play Licensing Library, revision 2
Found Google Play APK Expansion Library, revision 3
Found Google Play services, revision 10
Found Google USB Driver, revision 8
Found Google Play Billing Library, revision 4
Found Google AdMob Ads SDK, revision 11
Found Google Analytics App Tracking SDK, revision 3
Found Google Web Driver, revision 2
Found [Deprecated] Google Cloud Messaging for Android Library, revision 3
Fetching URL: https://dl-ssl.google.com/android/repository/extras/intel/addon.xml
Validate XML: https://dl-ssl.google.com/android/repository/extras/intel/addon.xml
Parse XML: https://dl-ssl.google.com/android/repository/extras/intel/addon.xml
Found Intel x86 Emulator Accelerator (HAXM), revision 3
Fetching URL: https://dl-ssl.google.com/android/repository/sys-img.xml
Validate XML: https://dl-ssl.google.com/android/repository/sys-img.xml
Parse XML: https://dl-ssl.google.com/android/repository/sys-img.xml
Fetching URL: https://dl-ssl.google.com/android/repository/sys-img/mips/sys-img.xml
Validate XML: https://dl-ssl.google.com/android/repository/sys-img/mips/sys-img.xml
Parse XML: https://dl-ssl.google.com/android/repository/sys-img/mips/sys-img.xml
Found Mips System Image, Android API 15, revision 1
Found Mips System Image, Android API 16, revision 4
Found Mips System Image, Android API 17, revision 1
Fetching URL: https://dl-ssl.google.com/android/repository/sys-img/x86/sys-img.xml
Validate XML: https://dl-ssl.google.com/android/repository/sys-img/x86/sys-img.xml
Parse XML: https://dl-ssl.google.com/android/repository/sys-img/x86/sys-img.xml
Found Intel x86 Atom System Image, Android API 10, revision 2
Found Intel x86 Atom System Image, Android API 15, revision 1
Found Intel x86 Atom System Image, Android API 16, revision 1
Found Intel x86 Atom System Image, Android API 17, revision 1
Done loading packages.
Validate XML
Parse XML
Preparing to install archives
Downloading Android SDK Platform-tools, revision 16.0.2
File not found: C:\Program Files (x86)\Android\android-sdk\temp\platform-tools_r16.0.2-windows.zip (Access is denied)
Downloading SDK Platform Android 3.2, API 13, revision 1
File not found: C:\Program Files (x86)\Android\android-sdk\temp\android-3.2_r01-linux.zip (Access is denied)
Downloading Samples for SDK API 13, revision 1
File not found: C:\Program Files (x86)\Android\android-sdk\temp\samples-3.2_r01-linux.zip (Access is denied)
Downloading Intel x86 Atom System Image, Android API 16, revision 1
File not found: C:\Program Files (x86)\Android\android-sdk\temp\sysimg_x86-16_r01.zip (Access is denied)
Downloading Mips System Image, Android API 16, revision 4
File not found: C:\Program Files (x86)\Android\android-sdk\temp\sysimg_mips-16_r04.zip (Access is denied)
Downloading Mips System Image, Android API 15, revision 1
File not found: C:\Program Files (x86)\Android\android-sdk\temp\sysimg_mips-15_r01.zip (Access is denied)
Downloading Google APIs, Android API 16, revision 3
File not found: C:\Program Files (x86)\Android\android-sdk\temp\google_apis-16_r03.zip (Access is denied)
Downloading Google APIs, Android API 15, revision 2
File not found: C:\Program Files (x86)\Android\android-sdk\temp\google_apis-15_r02.zip (Access is denied)
Downloading Google APIs, Android API 14, revision 2
File not found: C:\Program Files (x86)\Android\android-sdk\temp\google_apis-14_r02.zip (Access is denied)
Downloading Android Support Library, revision 18
File not found: C:\Program Files (x86)\Android\android-sdk\temp\support_r18.zip (Access is denied)
Downloading Google USB Driver, revision 8
File not found: C:\Program Files (x86)\Android\android-sdk\temp\usb_driver_r08-windows.zip (Access is denied)
Skipping 'Android SDK Tools, revision 22'; it depends on 'Android SDK Platform-tools, revision 16.0.2' which was not installed.
Skipping 'Google APIs, Android API 13, revision 1'; it depends on 'SDK Platform Android 3.2, API 13, revision 1' which was not installed.
Skipping 'Google TV Addon, Android API 13, revision 1'; it depends on 'SDK Platform Android 3.2, API 13, revision 1' which was not installed.
Skipping 'SDK Platform Android 4.1.2, API 16, revision 4'; it depends on 'Android SDK Tools, revision 22' which was not installed.
Done. Nothing was installed.
Can someone help me i'm having a problem when i try to install plug ins form the android SDK manager. It always gives me this message any help with this problem will be greatly appreciated
Validate XML
Parse XML
Validate XML
Parse XML
