hi .. my phone froze and would not switch on so i decided to reset it but now i am stuck on the downloading... do not turn off target screen ... i have been stuck here for a while now please help someone
): pull the battery, SIM card and sd card, wait, then do the button combination. While holding all three buttons, wait for the white "..Galaxy..." letters then quickly release all three buttons.
hi .. i have tried pulling it all and still nothing i pressed up wen the yellow triangle came on and it says odin mode nd small writing ... however i do not have a product name
If you're seeing a yellow triangle then you're not using the right button combination to get to the recovery menu, or the device is rooted and has its own non-stock recovery. Has your S3 been rooted at some point?
Please read the button combination carefully...and make sure your battery is 100% charged before doing anything more; in fact, have a look here:
Samsung Galaxy S3 hard reset - PDA Smartphone PNA hard reset soft reset
Read it all before doing anything.![]()
