Deepak Chauhan
Helo friends.
I have micromax A104 i had rooted it with kingo root app but now it is expired or unstable (whatever you can say) thats not the real problem. The problem is that some of the apps like ads hd videos, sudoku game, and some other .. They got installed into rom automatically i only could disable them . cant uninstall because now they are system apps and i dont have root. So i went into recovery which i installed before. Philz recovery. I wiped all data cache and also cleared the rom after that i had to install a new rom but when i tried to install the downloded .zip from computer it wont .. It says installation aborted. Some told me to use sp flash tools but it is not working even because when i switch off the device and connect to pc for some seconds it shows connected but as the screen turns on it gets disconnected.??? How to flash then??
then some told to unlock the bootloader i tried to do that but failed. Can anyone tell me howto install a new rom wihout any error.??
