Root Stupid Question about Roaming
wmbjr
I know this is probably a stupid question, but I noticed most of the ROM's available for the Eris are actually Sprint ROM's from the Hero or other phones. I assume since everyone is running these and not screaming about roaming charges, that they somehow know it is a Verizon phone and it uses the Verizon network? Or am I using the Sprint network when I use one of the Sprint ROM's. Just curious how it all works and making sure I am not going to be hit with roaming or using the Sprint network when I want Verizon. Thanks in advance for any clarification!
WB
Interesting.
Well, you don't have a plan with verizon, so they wouldn't even let you use their network.
As far as I know, Verizon phones can't function on Sprint's network due to the fact that the companies use entirely different frequency bands, so I don't see any way this could be an issue. I wouldn't worry about it.
Verizon : CDMA 850
Sprint: CDMA PCS (1900)
ATT: GSM 850
T-Mobile: GSM 1900
That's the majority of their networks, however VZ and Sprint roam each other, as well as with other networks that use CDMA and ATT and T-Mobile will roam each other if they have to.
